OBJECTISOLATIONMODE system variable
Object Isolation Mode
Specifies whether entities that are temporarily hidden with HIDEOBJECTS or ISOLATEOBJECTS remain hidden after saving and reopening the drawing.
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
0
Possible values:
0: Entities are temporarily hidden for the current session. Interfered solids are selected together with the interference solids.
1: Entities remain hidden between sessions. Interfered solids are selected together with the interference solids.
2: Entities are temporarily hidden for the current session. Interfered solids are not selected together with the interference solids.
3: Entities remain hidden between sessions. Interfered solids are not selected together with the interference solids.
