OBSCUREDCOLOR system variable
Obscured color
Specifies the color of obscured lines. This setting is visible only if OBSCUREDLTYPE is set to a value other than 0.
Type:
Short
Saved in:
Drawing
Range:
0 to 257
Default value:
257
Possible values:
0: ByBlock
1 - 255: index
256: ByLayer
257: ByEntity
