OBSCUREDCOLOR system variable
隐蔽线颜色
Specifies the color of obscured lines. This setting is visible only if OBSCUREDLTYPE is set to a value other than 0.
Type: | Short |
Saved in: | Drawing |
Range: |
0 to 257 |
Default value: |
257 |
Possible values: |
0: 依图块 1 - 255: index 256: ByLayer 257: 依对象 |
