OLEQUALITY system variable
OLE quality
Specifies the default plot quality of OLE (Object Linking & Embedding) entities. When set to 3 (Automatic), the quality level is assigned automatically depending on the entity e.g. photographs are set to High.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
0 to 3 |
Valore predefinito: |
3 |
Valori possibili: |
0: Monochrome 1: Low graphics 2: High graphics 3: Automatically Select |
