OLEQUALITY system variable
OLE quality
Specifies the default plot quality of OLE (Object Linking & Embedding) entities. When set to 3 (Automatic), the quality level is assigned automatically depending on the entity e.g. photographs are set to High.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 3 |
Default value: |
3 |
Possible values: |
0: Monochrome 1: Low graphics 2: High graphics 3: Automatically Select |
