OLEQUALITY system variable
OLE quality
Specifies the default plot quality of OLE (Object Linking & Embedding) entities. When set to 3 (Automatic), the quality level is assigned automatically depending on the entity e.g. photographs are set to High.
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
3
Possible values:
0: Monochrome
1: Low graphics
2: High graphics
3: Automatically Select
