OLESTARTUP system variable
OLE startup
Specifies whether or not the OLE (Object Linking & Embedding) entity source application is launched when plotting.
Tipo: | Booleana |
Salvato in: | Disegno |
Gamma: | OFF |
Valori possibili: |
Off (0): Don’t load OLE source application when plotting On (1): Load OLE source application when plotting |
