OLESTARTUP system variable
OLE startup
Specifies whether or not the OLE (Object Linking & Embedding) entity source application is launched when plotting.
Type:
Boolean
Saved in:
Drawing
Range:
Off
Possible values:
Off (0): Don’t load OLE source application when plotting
On (1): Load OLE source application when plotting
