ORBITAUTOTARGET system variable
Orbit Auto Target
Specifies how the target point is acquired for the RTROT command.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 1 |
Default value: |
0 |
Possible values: |
0: Off. The target point is located where you clicked to start orbiting 1: On. The target point is located at the center of the entities displayed or selected on screen. |
