ORTHOMODE system variable
Orthogonal mode
Specifies whether cursor movement is constrained to the perpendicular. When on, the cursor can be moved horizontally or vertically only, relative to the current UCS and grid rotation angle as defined by SNAPANG.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Orthogonal mode off On (1): Orthogonal mode on |
