ORTHOMODE system variable
Orthogonal mode
Specifies whether cursor movement is constrained to the perpendicular. When on, the cursor can be moved horizontally or vertically only, relative to the current UCS and grid rotation angle as defined by SNAPANG.
Type:
Boolean
Saved in:
Drawing
Default value:
Off
Possible values:
Off (0): Orthogonal mode off
On (1): Orthogonal mode on
