OSMODE system variable
对象捕捉模式
Specifies running entity snap modes. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
0 to 32767
Possible options:
4135
Possible values:
0: None
1: Endpoint
2: Midpoint
4: Center
8: Node
16: Quadrant
32: Intersection
64: Insertion
128: Perpendicular
256: Tangent
512: Nearest
1024: Geometric center
2048: Apparent intersection
4096: Extension
8192: Parallel
16384: Turn off all snaps
