OSNAPZ system variable
Ignore entity snap elevation
Replaces the Z coordinate of the entity snapping point with the current value of the ELEVATION system variable.
Tipo: | Booleana |
Salvato in: | Non salvato |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t replace Z value with current elevation On (1): Replace Z value with current elevation |
