OSNAPZ system variable
忽略对象捕捉高程
Replaces the Z coordinate of the entity snapping point with the current value of the ELEVATION system variable.
Type: | Boolean |
Saved in: | Not saved |
Default value: | Off |
Possible values: |
Off (0): Don’t replace Z value with current elevation On (1): Replace Z value with current elevation |
