OSNAPZ system variable
Ignore entity snap elevation
Replaces the Z coordinate of the entity snapping point with the current value of the ELEVATION system variable.
Type:
Boolean
Saved in:
Not saved
Default value:
Off
Possible values:
Off (0): Don’t replace Z value with current elevation
On (1): Replace Z value with current elevation
