OSOPTIONS system variable
Entity snap options
Suppresses entity snaps on certain entity types: hatches and/or dimension extension lines or negative z-values in dynamic UCS mode. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
0 to 7
Default value:
7
Possible options:
1: Entity snap ignores hatches
2: Entity snap ignores negative Z values in Dynamic UCS mode
4: Entity snap ignores end points of dimension extension lines
