PAPERUPDATE system variable
Paper update
About automatic papersize adaption when switching printers in print dialog. If ON, existing papersize is maintained. If the printer has no close match, the size will be displayed as 'previous paper size'. On print, user confirmation is required before substitution by default values. When OFF, always assigns the default papersize of the selected printer.
Tipo: | Booleana |
Salvato in: |
Registro di sistema |
Gamma: | 0 to 1 |
Valore predefinito: | 0 |
Valori possibili: | Off (0): Retain papersize when switching printers On (1): Use configured paper size of the plotter configuration file |
