PARAMETERCOPYMODE system variable
Parameter copy mode
Specifies copying of constraints and related parameters when entities are copied.
Type:
Short
Saved in:
Registry
Range:
0 to 4
Default value:
3
Possible values:
0: Do not copy 2D constraints
1: Replace all expressions with constants
2: Use existing parameters, if parameter is missing replace it with constant
3: Use existing parameters, create new parameter if it is missing
4: Use existing parameters, create new parameter if it is missing or has different value
