PDFEMBEDDEDTTF system variable
Pdf embedded fonts
Enable embedding of True Type fonts into PDF files.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | On |
Valori possibili: | Off (0): Disable embedded TTF fonts On (1): Enable embedded TTF fonts |
