PDFEMBEDDEDTTF system variable
Pdf embedded fonts
Enable embedding of True Type fonts into PDF files.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: | Off (0): Disable embedded TTF fonts On (1): Enable embedded TTF fonts |
