PDFIMPORTASBLOCK system variable
Import as block
Imports the PDF file as a block instead of directly into modelspace.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: |
OFF |
Valori possibili: |
Off (0): Don’t import PDF files as a block On (1): Import PDF files as a block |
