PDFIMPORTASBLOCK system variable
Import as block
Imports the PDF file as a block instead of directly into modelspace.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Don’t import PDF files as a block
On (1): Import PDF files as a block
