PDFIMPORTCHARSPACEFACTOR system variable
Inter-character space factor
Specifies the factor for the width of the space between characters in a word. If the distance between the text objects in the string is less than the width of the space taken from the font metric multiplied by this factor, the text objects are combined into one word. It is used only if the PDFIMPORTCOMBINETEXTOBJECTS system variable is turned on.
Solo-BricsCAD
Tipo: |
Reale |
Salvato in: |
Preferenza |
Valore predefinito: | 0.6 |
