PDFIMPORTCONVERTSOLIDSTOHATCHES system variable
Convert solid fills to hatches
Converts 2D solid entities into solid-filled hatches.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: |
OFF |
Valori possibili: | Off (0): Don’t convert solid fills to hatches from imported PDF files On (1): Convert solid fills to hatches from imported PDF files |
