PDFIMPORTCONVERTSOLIDSTOHATCHES system variable
Convert solid fills to hatches
Converts 2D solid entities into solid-filled hatches.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: |
Off |
Possible values: | Off (0): Don’t convert solid fills to hatches from imported PDF files On (1): Convert solid fills to hatches from imported PDF files |
