PDFIMPORTIMAGEPATH system variable
Raster Images Folder
Location for saving raster images when importing a pdf file containing rasters. The path can be absolute or relative. If PDFIMPORTIMAGEPATH is relative the pdf raster image path will be calculated relative to the folder of the current drawing file. If the path is left empty the folder of the current drawing will be used. The default value is a subfolder "PDF Images" of the current drawing. If the drawing has not yet been saved, rasters will be placed next to the pdf file being imported.
Tipo: | Stringa |
Salvato in: | Registro di sistema |
Valore predefinito: |
"PDF Images" |
