PDFIMPORTJOINLINEANDARCSEGMENTS system variable
Join line and arc segments
Joins contiguous segments into a polyline where possible.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Gamma: |
On |
Valori possibili: |
Off (0): Don’t join the line and arc segments from imported PDF files On (1): Join the line and arc segments from imported PDF files |
