PDFIMPORTJOINLINEANDARCSEGMENTS system variable
接合线和弧线段
尽可能将连续线段接合到多段线中。
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Range: |
On |
Possible values: |
Off (0): Don’t join the line and arc segments from imported PDF files On (1): Join the line and arc segments from imported PDF files |
