PDFIMPORTJOINLINEANDARCSEGMENTS system variable
Join line and arc segments
Joins contiguous segments into a polyline where possible.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Range: |
On |
Possible values: |
Off (0): Don’t join the line and arc segments from imported PDF files On (1): Join the line and arc segments from imported PDF files |
