PDFIMPORTLAYERSUSETYPE system variable
Layers
Specifies to which layers the entities are imported. It's possible to import to layers which match the PDF layers, to create layers for each PDF entity type, or to just collect all imported entities on the current layer.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Gamma: | 0 to 2 |
Valore predefinito: | 0 |
Valori possibili: | 0: Use PDF Layers 1: Layer per Entity Type 2: Use current layer |
