PDFIMPORTLAYERSUSETYPE system variable
图层
Specifies to which layers the entities are imported. It's possible to import to layers which match the PDF layers, to create layers for each PDF entity type, or to just collect all imported entities on the current layer.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
0 to 2
Default value:
0
Possible values:
0: Use PDF Layers
1: Layer per Entity Type
2: Use current layer
