PDFIMPORTSPACEFACTOR system variable
Inter-word space factor
Defines the factor for the width of the space between words on a line. If the distance between the text objects in the string is greater than the width of the space between characters in a word (specified by the PDFIMPORTCHARSPACEFACTOR system variable), but less than the width of the space taken from the font metrics multiplied by this factor, the text objects are combined into one word. It is used only if the PDFIMPORTCOMBINETEXTOBJECTS system variable is turned on.
Solo-BricsCAD
Tipo: |
Reale |
Salvato in: |
Preferenza |
Valore predefinito: | 1.5 |
