PDFIMPORTTRUETYPETEXTASGEOMETRY system variable
Import True Type text as geometry
Specifies whether to import True Type text from a PDF file as geometry.
BricsCAD only
Type: |
Boolean |
Saved in: |
Preference |
Default value: |
Off |
Possible values: |
Off (0): Don’t import TrueType text as geometry On (1): Import TrueType text as geometry |
