PDFIMPORTUSEIMAGECLIPPING system variable
Clip images
Controls whether images are clipped on import. Clipping means that the clipped part of the image becomes transparent. It has effect only if the PDFIMPORTUSECLIPPING system variable is on.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Preferenza |
Valore predefinito: |
OFF |
Valori possibili: |
Off (0): Images are not clipped on import. On (1): Images are clipped on import. |
