PDFIMPORTVECTORGEOMETRY system variable
Vector geometry
Ignore or Import vector geometry. PDF geometric data types include linear paths, Beziér curves, and solid-filled areas, which are imported as polylines, and 2D solids or solid-filled hatches. Within a tolerance, curves that resemble arcs, circles, and ellipses are interpolated as such. Patterned hatches are imported as many separate entities.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: |
On |
| Possible values: | Off (0): Don’t import vector geometry On (1): Import vector geometry |
