PDFLAYERSSETTING system variable
Pdf layer support
Specifies the use of layers in the target PDF document (PDF v1.5 feature).
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Valore predefinito: | 1 |
Valori possibili: | 0: Don't use layers 1: Use all layers with visible entities 2: Use all layers with entities, including OFF and FROZEN layers. |
