PDFLAYERSSETTING system variable
Pdf layer support
Specifies the use of layers in the target PDF document (PDF v1.5 feature).
BricsCAD only
Type: | Short |
Saved in: | Preference |
Default value: | 1 |
Possible values: | 0: Don't use layers 1: Use all layers with visible entities 2: Use all layers with entities, including OFF and FROZEN layers. |
