PDFMERGECONTROL system variable
Pdf Merge Control
Specifies the appearance of lines that cross.
Lines Overwrite Uses the last plotted line to obscure the lines under it. Only the topmost line is visible at the intersection.
Lines Merge Merges the colors of crossing lines.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Valore predefinito: | 0 |
Valori possibili: | 0: Lines Overwrite 1: Lines Merge |
