PDFMERGECONTROL system variable
Pdf 合并控制
Specifies the appearance of lines that cross.
Lines Overwrite Uses the last plotted line to obscure the lines under it. Only the topmost line is visible at the intersection.
Lines Merge Merges the colors of crossing lines.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Default value: | 0 |
Possible values: | 0: Lines Overwrite 1: Lines Merge |
