PDFNOTIFY system variable
PDF notify
Enables/disables the notification about missing or modified PDF documents when opening the parent drawing.
Solo-BricsCAD
Tipo:
Booleana
Salvato in:
Registro di sistema
Valore predefinito:
OFF
Valori possibili:
Off (0): Disable PDF notification
On (1): Enable PDF notification
