PDFNOTIFY system variable
PDF notify
Enables/disables the notification about missing or modified PDF documents when opening the parent drawing.
BricsCAD only
Type: | Boolean |
Saved in: |
Registry |
Default value: |
Off |
Possible values: | Off (0): Disable PDF notification On (1): Enable PDF notification |
