PDFNOTIFY system variable
PDF notify
Enables/disables the notification about missing or modified PDF documents when opening the parent drawing.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disable PDF notification
On (1): Enable PDF notification
