PDFOSNAP system variable
PDF 对象捕捉
Enable snapping to entities in the PDF underlay files.
Type: | Boolean |
Saved in: |
Registry |
Default value: |
On |
Possible values: | Off (0): Disable PDF entity snap On (1): Enable PDF entity snap |
