PDFPAPERSIZEOVERRIDE system variable
Pdf papersize override
Enables papersize override. If On, the papersize as defined in the BricsCAD Print settings is overridden. The papersize width and height defined by PdfPaperWidth and PdfPaperHeight are used instead.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: |
OFF |
Valori possibili: | Off (0): Disable papersize override On (1): Enable papersize override |
