PDFPAPERSIZEOVERRIDE system variable
Pdf papersize override
Enables papersize override. If On, the papersize as defined in the BricsCAD Print settings is overridden. The papersize width and height defined by PdfPaperWidth and PdfPaperHeight are used instead.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: |
Off |
Possible values: | Off (0): Disable papersize override On (1): Enable papersize override |
