PDFPAPERSIZEOVERRIDE system variable
Pdf papersize override
Enables papersize override. If On, the papersize as defined in the BricsCAD Print settings is overridden. The papersize width and height defined by PdfPaperWidth and PdfPaperHeight are used instead.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Disable papersize override
On (1): Enable papersize override
