PDFPRCCOMPRESSION system variable
PRC Compression
Specifies the compression for PRC 3D data.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 2 |
Default value: |
0 |
Possible values: |
0: No compression 1: Medium compression 2: High compression |
