PDFPRCEXPORT system variable
PRC Export Mode
Specifies the export mode for PRC 3D data. Export as BREP is an experimental mode which may work incorrectly. We recommend using Export as Mesh mode.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Preferenza |
Gamma: |
0 to 2 |
Valore predefinito: |
0 |
Valori possibili: |
0: No export 1: Export as BREP (Experimental) 2: Export as Mesh |
