PDFPRCEXPORT system variable
PRC Export Mode
Specifies the export mode for PRC 3D data. Export as BREP is an experimental mode which may work incorrectly. We recommend using Export as Mesh mode.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 2 |
Default value: |
0 |
Possible values: |
0: No export 1: Export as BREP (Experimental) 2: Export as Mesh |
