PDFSIMPLEGEOMOPTIMIZATION system variable
Pdf simple geometry optimization
Enable simple geometry optimization (separate segments to one polyline, use of Bezier curve control points).
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: |
On |
Valori possibili: | Off (0): Disable simple geometry optimization On (1): Enable simple geometry optimization |
